Author Topic: a/c help  (Read 6151 times)
Offline tater48
a/c help
« on: December 11, 2012, 07:37:55 pm »
i have a 86 silverado with a 350. does anyone know where the wire from the a/c compressor goes to? it was clipped by the previous owner and i dont know where it is supposed to be, everything works otherwise but the compressor wont lock up
my mom never understood why i laughed when she called me a son of a $#@%
Re: a/c help
« Reply #1 on: December 11, 2012, 08:44:07 pm »
On the factory A/C system, a dark green wire runs from the compressor toward the back of the engine then over to the low pressure cycling switch that threads into the accumulator on the passenger side evaporator housing.  From there the wire color changes to light green and runs into the dash controls.  A second (black) wire runs from the compressor clutch to an intake manifold ground stud adjacent to the compressor.
« Last Edit: December 12, 2012, 01:42:38 am by bd »
Offline tater48
Re: a/c help
« Reply #2 on: December 11, 2012, 09:39:09 pm »
i cant seem to open that picture  :-\ , so if i understrand this right do i just ground the wire coming off the compressor?
Re: a/c help
« Reply #3 on: December 12, 2012, 01:35:09 am »
There should be two wires off the compressor: one (a dark green power wire) connects to the switch on the accumulator, the other (black) connects to an engine ground stud near the compressor.  The compressor requires both wire connections to engage.
See if you're able to open the wiring diagram here...  http://forum.73-87chevytrucks.com/smforum/index.php/topic,24981.msg208148.html#msg208148
Re: a/c help
« Reply #4 on: December 13, 2012, 01:09:29 pm »
You can see the green wire here with a grey connector on it right under the firewall clamp.  Yours  should come from the same place.
Offline tater48
Re: a/c help
« Reply #5 on: December 20, 2012, 09:21:46 pm »
oh ok thanks bud, im gonna give it a look soon, i appreciate it
