Author Topic: Used headers  (Read 5496 times)
Offline 86c10
Used headers
« on: December 14, 2012, 08:50:58 am »
I have a set of headers that have a couple of small cracks. I think the truck they came out of over heated and that might be why they cracked. One is on the collector and they other is on the primary near the flange. Is it worth trying to weld the cracks and use them or should they just go in the scrap pile? I've checked the flanges with a straight edge and they are fine.
Offline gildardo01
Re: Used headers
« Reply #1 on: December 14, 2012, 06:00:17 pm »
if you have a welder, sure weld them and reuse them, if you have to pay to get them welded up might want to consider the cost of the welding first...
Offline Tx_Phil
Used headers
« Reply #2 on: December 14, 2012, 06:47:25 pm »
If you can do the welding then you've got nothing to loose but some time and maybe a set of gaskets.
Are you putting them back in the same engine\heads they came off of?  My concern would be that the flanges may have warped and you won't get a good seal at the head.
Offline thirsty
    • Suitor's Garage
Re: Used headers
« Reply #3 on: December 14, 2012, 09:55:30 pm »
If you can weld I would weld them up. Like Tx-Phil said you will only be out some gaskets and you could even reuse those if you had to.
Re: Used headers
« Reply #4 on: December 15, 2012, 08:43:46 am »
      You have to careful of the heat you apply, they will warp if too much heat is used.  Check them when you are done again before putting them on.
Offline 86c10
Re: Used headers
« Reply #5 on: December 15, 2012, 07:28:24 pm »
Thanks guys, I do have a MIG so welding them myself is no problem. They came out of a parts truck so they aren't going back on the motor they came off of.
Offline gildardo01
Re: Used headers
« Reply #6 on: December 15, 2012, 08:18:36 pm »
yeah forgot to mention that.... definitely have to consider the heat... have to weld them as if you were welding thin sheet metal...
Offline 86c10
Re: Used headers
« Reply #7 on: December 16, 2012, 08:14:59 am »
I figured I would have to go easy on them, I think they are just cheap summit brand headers.
Has anybody used the VHT header paint?
