Author Topic: Damaged factory tach gauge cluster  (Read 4933 times)
Offline gusto81
« on: December 26, 2012, 05:56:12 pm »
I recently purchased a fact. gauge cluster out of a 1981 c-10 1/2t 2wd donor truck with plans on installing it in my '81 c-10 1/2t 2wd. My problem is I damaged the case (tach. gauge) during removal. Everything is still intact except the top mounting bracket (for the bezel?) broke and the housing also cracked. Can I use (switch) my original housing?
Re: Damaged factory tach gauge cluster
« Reply #1 on: December 26, 2012, 07:46:11 pm »
     Are You asking if you can gut the new one and put it in your old housing ?  I believe the Gauges have been sealed, Have you checked to see if you can take it apart ?
« Reply #2 on: December 30, 2012, 12:47:59 pm »
Take a picutre of what you broke, I am not following what is broken.
Offline gusto81
« Reply #3 on: January 01, 2013, 01:34:15 am »
The top mounting bracket, (files too large for transfer).
« Reply #4 on: January 01, 2013, 03:17:02 pm »
The plastic casing?  compare it to what you currently have, or if you still have the broken piece epoxy it back together.
Offline Jason S
« Reply #5 on: January 24, 2013, 11:44:12 pm »
The white plastic housing that the gauges mount into are different between the tachometer cluster and the non-tachometer cluster.  You would need to find another undamaged tachometer gauge cluster housing to swap your gauges/tach into or repair what you have (maybe using the mounting tabs off an old cluster).
