Author Topic: Small vibration only when turning right  (Read 5510 times)
Offline gabriel83chevy
« on: December 30, 2012, 07:15:21 pm »
Any ideas on why i could have vibration when i veering right on a curve. I was thinking rotor but unsure. Its not all that bad but is annoying as i take a curve.
Lifted 1983 Chevy c20, 350
Re: Small vibration only when turning right
« Reply #1 on: December 30, 2012, 07:20:53 pm »
Check to see if your wheel bearings are tight.
« Reply #2 on: December 31, 2012, 12:27:34 pm »
X2.  By steering right on a curve, you are transferring more weight to the left side, so you should check both sides for not only the wheel bearings but to make sure nothing is loose or becoming loose on either side.
     If your rotor was warped or bent, if would effect it first when braking, then as it gets worse all the time.
« Last Edit: December 31, 2012, 12:31:04 pm by bake74 »
Offline Engineer
« Reply #3 on: December 31, 2012, 10:40:08 pm »
When was the last time you rotated your tires? Cupping, or feathering of the tread will cause a vibration when the wheels are cut, but usually only at lower speeds.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #4 on: January 01, 2013, 07:22:47 pm »
Haven't rotated tires yet. I'm thinking worse case scenario. this is my daily driver project.
