Author Topic: 85 silverado engine swap  (Read 3989 times)
Offline 85silverado@yahoo.com
« on: December 30, 2012, 08:37:18 pm »
Im trying to switch a 1993 chevy 355 from tbi to carb.. And i know i need the carb and a new intake but im concerned with the distributor.. Idk if im gonna have to get a new one that will work for the connections on the 85 silverado because i do not have the wiring harness or computor for the 93 z71 the engine came out of. Any help is greatly appreciated. Thankyou
Offline Engineer
Re: 85 silverado engine swap
« Reply #1 on: December 31, 2012, 05:49:04 am »
The 1993 distributor will not work in your '85.
Get an older fat cap HEI out of a '75~'86 truck, and all should be good. They are everywhere, and cheap. :)
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #2 on: January 02, 2013, 04:41:19 pm »
Ok thats what i figured thankyou.. The engine i have in my truck now is an older 350 around the 80's so i was woundering if i could just pull that distributor out and put it in the 93 engine? I just dont know if the gear and rod would work for the 93 engine.. Thanks for the help
« Reply #3 on: January 03, 2013, 07:35:04 am »
It will drop right in. Clean and inspect it well though, check for play between the shaft, and housing. It should little to none. If it has play I would look for a better used, or a new one.
« Reply #4 on: January 03, 2013, 10:42:11 am »
Ok thanks a lot man i appreciate the help
