Author Topic: 454 question  (Read 2746 times)
Offline bigchevyc30
  • the pig
454 question
« on: January 01, 2013, 08:45:59 am »
ok i have a 82 c30 with the stock engine and stock set up it might have raised gears idk but today on my way home from work which is 62 miles 1 way i decided to do a little testing of what its max speed was. well by what i know it feels like it has more to give but once i hit 85 it drops down to 75 then it recatches its self would this be not enough fuel at wot. if anyone can help me please let me know cause even going down the road if its a wot for accelerating it has a good bit of lag and somewhat surging
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Re: 454 question
« Reply #1 on: January 01, 2013, 09:52:04 am »
Sounds like your fuel filter to me needs to be replaced
Offline bigchevyc30
  • the pig
Re: 454 question
« Reply #2 on: January 01, 2013, 09:55:26 am »
where would the fuel filter be on my truck is it like most vehicles on the frame rail or is it in the carb
Re: 454 question
« Reply #3 on: January 01, 2013, 09:57:35 am »
Carb, take the fuel line loose at the carb and there is a housing that you remove that takes a 1" wrench, the fuel line is a 5/8" wrench
