Author Topic: th350-nv3500 swap  (Read 9467 times)
Offline 79brent
  • Shake and Bake!
th350-nv3500 swap
« on: January 01, 2013, 11:26:42 pm »
Ok so I have a th350 that has been making noise and slipping so it need to be replaced. I got a quote for a beefed up 700r4 tranny for towing at $2000 out the door installed with everything I need. However, I found a guy on craiglist with a 2000 chevy wrecked with the nv3500 bolted to a 4.3 with 85k on it for $500 with the transmission, clutch, hydraulics basically everything I need except for the v8 flywheel and high hump transmission tunnel.
Now my questions/concerns  ::)
Will this transmission hold up to a stock 350 with mild towing say 2 tons? I plan on building the soon as well
Would I need to change the tunnel?
What else would I possibly need for the swap? After getting all the parts-flywheel, tunnel, pedal assembly and a shop install, would I be better off going with the hopped up 700r4 or the nv3500?
1979 Chevy C10 Silverado package. 350/350
"Lifes a garden DIG it"
Offline 79brent
  • Shake and Bake!
Re: th350-nv3500 swap
« Reply #1 on: January 02, 2013, 02:02:07 pm »
I think it would be better with the nv3500. But ive have always wanted a stick shift in there anyways. Anyone have any experience with this I need to buy it soon.
Offline 79brent
  • Shake and Bake!
« Reply #2 on: January 04, 2013, 12:28:40 pm »
Found out it will fit my low hump tunnel, barely, but will work. What flywheel should I use? I got an 85 motor, made in mexico. Does anyone know if they make reproduction 85-91 hydraulic clutch pedal assemblies? I checked and came up with nothing. ???
« Last Edit: January 04, 2013, 08:05:59 pm by bd »
Offline wrench
« Reply #3 on: February 22, 2013, 11:25:19 pm »
this is what I want to do to my 82 gmc,I found out that GM had a hydraulic clutch setup in some 85 thru 87 chevy and gmc pickups that will work for the clutch setup.Not sure about the rest.I plan on doing this swap when I get all the parts
« Reply #4 on: February 26, 2013, 05:01:33 pm »
I know of no aftermarket repro of the hydraulic clutch setups.  It is salvage only item.  Of course several companies make hydraulic setups.
