Author Topic: 6 INCH LIFT 38 INCH TIRES  (Read 62129 times)
Offline TOMMYCROW44
  • 77 K10
« on: January 02, 2013, 12:36:42 pm »
I HAVE A 77 K10 THAT I HAVE PURCHACED A 6 INCH ROUGH COUNTRY LIFT KIT FOR AND SOME 38 INCH SUPER SWAMPER BOGGERS. I WAS WONDERING IF ANY ONE HAS THE SAME SET UP AND IF THEY HAVE RAN INTO ISSUES IF ANY? THE KIT AND WHEELS WILL BE GETTING INSTALLED IN A WEEK AND A HALF.
SITTIN' HIGH
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: 6 INCH LIFT 38 INCH TIRES
« Reply #1 on: January 02, 2013, 02:12:50 pm »
Mine runs on forties, 38's on 6 inches is tight, depending on how much articulation youre have in your suspension going hard offroad won't be a option. Are you getting all 6 inches from spring lift? If so add a 3' body lift and those tires won't be so angry with the fenders.
Offline TOMMYCROW44
  • 77 K10
« Reply #2 on: January 02, 2013, 03:42:29 pm »
SHE'S NOT GOING TO SEE TO MUCH WHEELING JUST MOSTLY CAMPING TRIPS AND AN OCCATIONAL MOUNTAIN SNOW TRIP THE LIFT CONSISTS OF SPRINGS UP FRONT AND 4 INCH BLOCKS WITH AN ADD A LEAF IN THE REAR, IVE HEARD I HAVE TO TRIM THE FENDERS SO IM KINDA WAITING TO SEE HOW MUCH. HAVE YOU HAD ANY ISSUES WITH DEATH WOBBLES?
SITTIN' HIGH
Offline TOMMYCROW44
  • 77 K10
« Reply #3 on: January 02, 2013, 06:33:00 pm »
ALSO IF ANY ONE HAS HAD ISSUES WITH BRAKE LINE RELOCATIONS, THEY HAVE SOME BRACKETS IN THE KIT, ARE THOSE ANY GOOD?
SITTIN' HIGH
Offline thirsty
    • Suitor's Garage
« Reply #4 on: January 02, 2013, 06:52:08 pm »
If you are talking about the small bracket at the rear differential...yes it will work. You may have to replace the rear wheel cylinder lines to reach though.
Offline pholliday1
« Reply #5 on: January 03, 2013, 07:44:24 am »
No death wobble here, I have a dana 60 with a 2wd steering box and a crossover steering setup. That type of wobble is associated with improper castor/camber issues (not being aligned right). 38's on 1/2 ton axles are really to much for the stock brake setup however there are alot of people who do it, just make sure you back up your stopping distance. The brake line reroute is pretty straight forward.
Offline TOMMYCROW44
  • 77 K10
« Reply #6 on: January 03, 2013, 01:54:13 pm »
THAMKS FOR THE ADVICE! YOU HEAR HORROR STORIES FROM SOME GUYS AND NOTHING BUT GREAT REVIEWS FROM OTHERS. I'LL POST SOME BEFORE AND AFTER PHOTOS ONCE THE KIT GETS HERE.
SITTIN' HIGH
Offline TOMMYCROW44
  • 77 K10
« Reply #7 on: January 04, 2013, 10:16:50 am »
SO THE LIFT KIT WILL BE HERE TODAY AND INSTALLED ON SUNDAY ;D AGAIN I'LL POST SOME BEFORE AND AFTER PICTURES, WISH ME LUCK. ALSO I LIVE IN WASHINGTON DOES ANY ONE KNOW THE MUDFLAP LAWS?
SITTIN' HIGH
Offline TOMMYCROW44
  • 77 K10
« Reply #8 on: January 04, 2013, 06:41:18 pm »
Lift kit just showed up and sunday is the first day off so wish me luck. 8)
SITTIN' HIGH
« Reply #9 on: January 04, 2013, 08:34:37 pm »
Good Luck!
Offline pholliday1
« Reply #10 on: January 05, 2013, 01:59:03 pm »
Start early in the morning LOL!!
Offline TOMMYCROW44
  • 77 K10
« Reply #11 on: January 07, 2013, 11:05:45 am »
HE IS SOME PICTURES BEAR WITH ME IM TRYING TO GET THEM LOADED 8)
SITTIN' HIGH
Offline TOMMYCROW44
  • 77 K10
« Reply #12 on: January 07, 2013, 11:15:18 am »
How do you post pics it keeps telling me the file is to big?
SITTIN' HIGH
« Reply #13 on: January 07, 2013, 03:33:03 pm »
There is a post in the Tech section on how to resize photos to fit.  They need to be a jpg or tiff image and need to be around 800x600 resolution.
Offline ehjorten
« Reply #14 on: January 08, 2013, 10:19:10 am »
I would be extremely surprised if your 6" lift is compatable with 38" tires.
Washington Mud-flap law is that the mudflap must cover the entire width of the tread and come down to the centerline of the axle (I'm in WA too).
« Last Edit: January 08, 2013, 10:20:59 am by ehjorten »
-Erik-
