Author Topic: Electric choke setup  (Read 9084 times)
Offline 81_Chevy
« on: January 04, 2013, 10:02:27 pm »
ok so i got a new carb for my 81. it has a 350, all stock engine wise. ive used the search and didnt come up with much help. im confused on how to hook up the electric choke, like wire wise. right now i have the hot air choke on my old carb and i would like to know how to hook the electric one up when i go to swap the carbs. thanks in advance,
-Nic
Offline projectC10
Re: Electric choke setup
« Reply #1 on: January 04, 2013, 10:34:11 pm »
You should have a green wire in the engine bays wiring harness. The green is the electric choke. Hook this wire up to the electric choke. I believe passenger side. Also check to see if there is a fuse for the electric choke. If not install one.
Offline str8bloc
  • MISTRESS
« Reply #2 on: January 05, 2013, 10:10:57 am »
ive hooked my edelbrock carb with a 12v on the fusebox as per edelbrock
FaTbOy
Offline blazing816
« Reply #3 on: January 06, 2013, 06:39:54 pm »
my green wire was removed from the PO so I just used a switched 12v power lead. Works like a champ.
« Reply #4 on: January 06, 2013, 08:56:25 pm »
...i would like to know how to hook the electric [choke] up when i go to swap the carbs....
Run fused ignition through an oil pressure switch that's made to control a "choke light."
http://www.autozone.com/autozone/parts/Duralast-Oil-Pressure-Switch/1985-Chevrolet-C10-1-2-ton-P-U-2WD/_/N-ijk0vZ8znc6?itemIdentifier=123521_44645_9889_5835
