Author Topic: Time for a new transmission?  (Read 3908 times)
Offline kmanrsss
« on: January 05, 2013, 02:42:52 pm »
I'm having issues with my plow truck. 87 chevy v20. When shifting to reverse it will sometimes catch, some times not. It feels like its slipping like crazy until it gets enough rpm that it will start to move. Pulled it out to drop the plow so it could go on the lift and there's smoke pouring outta the trany dip stick tube. I'm thinking time for a new one? Anything to check before pulling it out? Thanks
« Last Edit: January 05, 2013, 07:02:40 pm by kmanrsss »
Offline 81_Chevy
Re: Time for a new transmission?
« Reply #1 on: January 05, 2013, 09:02:08 pm »
when was the last time it was rebuilt?(if ever) have you check the tranny fluid level? filter?
« Reply #2 on: January 05, 2013, 10:47:31 pm »
yeah, smoke out the dipstick tube is BAD!  ???
Offline kmanrsss
« Reply #3 on: January 06, 2013, 12:28:47 pm »
Don't know if its ever been rebuilt. I've only had the truck since last spring and i only test drive it around the cul-de-sac then went to work repairing rust and rot. I plowed the 2 small storms that we've had and reverse is getting worse and worse. Guess its coming out. Just what I need. O well such is life.
Offline kmanrsss
« Reply #4 on: January 06, 2013, 12:59:55 pm »
Levels look fine, it's got an orangish brown color though, not reddish.
Offline pedigo78
  • Big Blue
« Reply #5 on: January 06, 2013, 01:20:24 pm »
Sounds like you have more than ony problem. It only taking off hwen you get up to RPM sounds like the convert is going, or maybe your clutches.
Sgt Pedigo USMC
« Reply #6 on: January 06, 2013, 04:29:16 pm »
     I bet when you get it open all kinds of things are going to be burnt. :o  >:(
Offline kmanrsss
« Reply #7 on: January 09, 2013, 08:21:12 pm »
Got the tranny out of the truck tonight. Removed the transfer case and this is what i found. looks like the case is broken to me, but ive never taken one of these apart. that break on the right side isn't normal, right? I'm thinking I'm going to be looking for more then just a rebuild.
Offline pedigo78
  • Big Blue
« Reply #8 on: January 09, 2013, 08:37:34 pm »
Yeah looks broke to me. Well atleast you now you know not to waste your time rebuilding it. Just get a new one. Monster Transmission take a look at there site.
Sgt Pedigo USMC
