Author Topic: Will these work for my application?  (Read 4873 times)
Offline Da67goatman
  • Burban
« on: January 22, 2013, 04:24:58 pm »
http://www.summitracing.com/parts/cal-220261401
I really like these gauges, but I'm not sure if they will work for me.  I have ALL electric gauges from the factory including Speedometer, but NO tach currently.  If I get these what all is involved in making them operational.  Will I have to add another sending unit for each gauge or can I just tap into the factory units.  Thanks for your assistance.
<Pitcrew>
Re: Will these work for my application?
« Reply #1 on: January 23, 2013, 07:41:34 am »
     They seem like they will work.  My only concern is like you said you might have to splice into yours since these are universal.  Are you planning on adding a tack to your set up ?
Offline Da67goatman
  • Burban
« Reply #2 on: January 23, 2013, 11:00:13 am »
Yes I am actually planning on using all 6 of those gauges and getting a trans temp, Vacuum and oil temp gauge also.  The layout will be revised to put the important stuff in the center and 4 of the smaller gauges at each side, just like the picture, with those extra 3 in a pillar pod.
<Pitcrew>
« Reply #3 on: January 23, 2013, 06:08:20 pm »
     That should look good, pictures please when you get it done.
Offline Da67goatman
  • Burban
« Reply #4 on: January 23, 2013, 11:11:35 pm »
I promise to get pics, but as to when this is going to happen is still up in the air, planning for around May...ish
<Pitcrew>
