Author Topic: 84 C10 LWB - 507CI - 9 INCH  (Read 32700 times)
Offline CanadianC10
Re: 84 C10 LWB Swap - 507CI CADILLAC
« Reply #30 on: September 14, 2014, 02:13:13 pm »
VIDEO
https://www.youtube.com/watch?v=Iw5AZuM5Co4
truck slowed down a bit due to conservative timing.. running pump gas
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
Offline CanadianC10
Re: 84 C10 LWB - 507CI CADILLAC VIDEO
« Reply #31 on: September 17, 2014, 04:58:54 pm »
Things ill be doing this winter.
- 4000 Stall Converter from Coan Engineering.
- Standard Brakes
- Standard Steering
- Fuel Cell
- Aeromotive Fuel System
- Electric Water Pump
- Home made Wide band O2
- Cal Trac Bars
- 90/10 Front Shocks
- Headers coming shortly, 1 7/8 primarys
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline CanadianC10
« Reply #32 on: January 17, 2016, 04:10:18 pm »
Decided im going to race this year, started working on the truck.
Putting a coan brake in my TH400. Got some billet wheels with 295 radials, figured im gonna need beefier rear with the car pattern.
the motor bent a crossmember in the rear while racing with no bumper on it, too much twisting, added in some DOM tubing. much stronger.
Took a housing out of a van, extra wide 68".. cut it for optimum wheel placement at 64 1/2, only cut a piece out the driverside in order to help center the pinion.
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline CanadianC10
« Reply #33 on: January 17, 2016, 04:11:49 pm »
more
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline FearNoMan78k10
  • A project turned into a complete rebuild
Re: 84 C10 LWB - 507CI - 9 INCH
« Reply #34 on: January 17, 2016, 09:37:27 pm »
507ci is insane.....engine is a monster and will probably drink fuel like a camel drinks water!
78 k10 4x4
Offline CanadianC10
« Reply #35 on: January 18, 2016, 10:19:49 pm »
its not too bad. AFR gauge helps to keep it inline
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline CanadianC10
« Reply #36 on: November 05, 2016, 03:18:36 pm »
Update on the truck.
 After a couple life changes the truck went back into hiding. I rebuild the transmission and finished everything off over the last couple months.
The motor is back in the truck along with the rebuilt th400. The 9 inch is all buttoned up.
Made clearance for the new headers.
Next up: Going to use camaro rotors and obtain a 4 3/4 bolt pattern to fit some nice wheels, while installing all new bushings and ball joints to keep the MTO happy.
1984 C10 LWB
CADDY 507
TH400
Frame twister
