Author Topic: The Wife's 88 CrewCab Makeover  (Read 99141 times)
Offline Engineer
Re: The Wife's 88 CrewCab Makeover
« Reply #15 on: January 27, 2013, 07:35:38 pm »
I approve of this project. You may continue. :)
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline big bear
« Reply #16 on: January 27, 2013, 08:41:51 pm »
wow man..what a killer story,and build. the truck is so nice looking. least for my area in ohio haha. i know i would have been all over those bench seats you pulled out. i cant find a set anywhere .
Offline rhino
« Reply #17 on: January 28, 2013, 12:32:22 pm »
Thanks. where abouts in Ohio? I still have them.
After I tackled the floor, I moved on to the brakes suspension and chassis. I started with the front. Completely gutting the front end. putting in new Ball joints, bushings, springs, Brakes, calipers Cleaning and Re-packing the bearings with Amsoil grease. I freshened up the steering  with newt tie-rods,  center link, idler arm Pitman arm, a new P/S gearbox. Then finished off with a new set of wheels.
« Last Edit: January 28, 2013, 02:18:12 pm by rhino »
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #18 on: January 28, 2013, 02:54:27 pm »
Is there a new grill 89-91 side by side headlight grill in your future?
Offline big bear
« Reply #19 on: January 28, 2013, 04:17:03 pm »
No prob. I'm east of cleveland.where exactly you located?
Offline rhino
« Reply #20 on: January 28, 2013, 04:53:38 pm »
Nope. I keep the stock grill,  I just put my own little customizing twist on it.
Offline Trimmy
« Reply #21 on: January 28, 2013, 08:54:51 pm »
Nice build. Im in Ohio also, and have more tore apart in the garage. Im in Brookville which is the Dayton area.
Offline rhino
« Reply #22 on: January 29, 2013, 08:03:11 am »
Ah Yes. Someday (sooner than Later) I'm going to visit your Beautiful town and pick up my new 32 Ford Brookville roadster body.
Offline rhino
« Reply #23 on: January 29, 2013, 08:39:56 am »
Until I get my Brookville roadster. I guess Ill keep going on the crew cab.  After doing the front I went to the rear. After taking off those heavy Im heavy Drum brakes from the 14 bolt. I swap them out for a set of disc brakes. I bought caliper brackets from a offroad website.
 I put on new calipers pads and rotors from a 78 k20. I made my own Brake hose brackets and put in new bearings and seals in the full floating hub. I was contemplation installing new 3.:73 gears But in the end decide to keep the 4:11 that were already in there. while I had it apart I installed new carrier bearing and pinion bearings and seal. Then added Amsoil Gear lube
Got the wife out to bang on the studs.
Get your last look at a long bed.
Offline silverj
« Reply #24 on: January 29, 2013, 05:50:50 pm »
Any plans for an e-brake, like eldorado calipers or anything?  By the way very nice build!
87 R20
Offline rhino
« Reply #25 on: January 29, 2013, 06:15:07 pm »
No plans for ebrake. I dont use em. they tend to stick and cause more problem than there worth. at least in my area.
Offline silverj
« Reply #26 on: January 29, 2013, 06:18:44 pm »
I can not pass inspection here without one.
87 R20
Offline oneIwilly
« Reply #27 on: January 29, 2013, 06:28:18 pm »
Man, that looks nice. Now I have to go search craigs list for some nice leather seats for my truck!
Offline rhino
« Reply #28 on: January 29, 2013, 07:18:03 pm »
Yea we don't have any inspections here. if we did I betcha half the junk on our roads wouldn't pass.
Offline rhino
« Reply #29 on: January 29, 2013, 07:20:16 pm »
They sit so nice too. way better than what was in there and better than my 86 shortbed.
