Author Topic: The Wife's 88 CrewCab Makeover  (Read 99789 times)
Offline rhino
Re: The Wife's 88 CrewCab Makeover
« Reply #45 on: February 10, 2013, 08:35:18 am »
Glad to have you here rhino. I came across your Silver Dollar build thread while doing some searching for paint colors. I kept going back to check your progress. You did a great job on that one and I'm sure this one will be no different.
Best part is the involvement of the whole family.
Thanks,  Its good to be here.  Its nice having the whole family join in.(most of the time) Deb's getting more involved in this one. Since its her truck she better. I told her, she is putting the engine together.  :o   That should be interesting, considering she got mad at me just yesterday. I saw her trying to start a crooked bolt with the ratchet.  Apparently, I stopped her in a harsh and condescending way.  (My bad) ::)
Offline rhino
« Reply #46 on: February 10, 2013, 08:38:15 am »
Well, you've done everything else to it, might as well throw a Dana60 front end under it.
Lets go, chop, chop, whatta ya waiting for?
hum.. I dont know about that one.
;D
Offline thirsty
    • Suitor's Garage
« Reply #47 on: February 10, 2013, 10:50:44 am »
So you took her out to dinner and everything is alright now?  ;D
Been there having the wife help me out on a job site a few times...I talked to her like she was an employee. (My bad too) ???
Offline rhino
« Reply #48 on: February 10, 2013, 12:54:47 pm »
  I just apologized for being a jerk and were ok now.
« Last Edit: February 18, 2013, 01:10:49 pm by Captkaos »
« Reply #49 on: February 10, 2013, 05:22:43 pm »
    UH,  :o better count me as 3, and let me tell you my wife can snap back when I forget she is not one of my employee's.   :-X
Offline rhino
« Reply #50 on: February 13, 2013, 08:20:40 am »
5 long months of body work, in a few short days
We started by prepping the body. Sanded and checking for any imperfection, then a good cleaning cleaning to remove any containment's.
I replaced the driver door. It was full of filler from a large dent. and I replaced the right front fender, it had some damage as well.
Then I shot it with 2 coats SPI black epoxy primer. No need for guide coat with this epoxy. The primer dries to a nice semi-gloss black. and you can perfectly see any imperfections when sanded.
once it was sanded and all low and high spots were revealed. I started in with the filler. Rage Extream was my choice. very little shrinkage and sands easy.
« Last Edit: February 13, 2013, 08:24:58 am by rhino »
Offline frotosride
    • WFO CONCEPTS
« Reply #51 on: February 13, 2013, 08:16:16 pm »
This has got to be the best pic yet. After blocking out old blue I knew I wasn't a paint and body guy. There's not better way to appreciate something than to be involved in building it. I had to get a new military id shortly after blocking the truck but the scanner couldn't find my finger prints so I looked at my fingers and realized it was because I had none...
I sure hope at least one of my four will enjoy hitting the wrenches with old dad.
Oh, Waiting for more pic's....and the Dana 60..
Offline rhino
« Reply #52 on: February 14, 2013, 08:03:13 am »
The wife helped me sand a few days. I left the tailgate and the hood to her. so if there not straight.  She did it.
after sanding the filler, I shot some more epoxy primer on the truck. You can still see where all the filler work was done.  The filler soaked up the epoxy like a sponge. but thats ok.
Then I laid down two coats of Feather fill. (Gray polyester primer) The feather fill is thick and helps fill in the small imperfections kinda like a skim coat of body filler.
Then some sanding and more sanding. I sprayed on some guide coat. then did some more sanding.  I used dura-blocks 16" 11" and a tear drop block for the curves.
As I was sanding I would put little pieces of tape on spots that I found that need just a little more filler.
« Reply #53 on: February 14, 2013, 04:08:49 pm »
You're inbox is full
Offline rhino
« Reply #54 on: February 14, 2013, 05:29:38 pm »
only had 5 messages.  i have a little room now
Offline rhino
« Reply #55 on: February 16, 2013, 08:40:49 am »
After all the Feather fill was sanded and all the little things fixed, I sprayed on another round of epoxy. At this point The truck should be nice a straight. But Its time again for some more sanding. this time with 400.  Even suckered my dad into helping.
 I mixed up some epoxy with reducer.  Let it induce overnight so I can use it as sealer.
« Reply #56 on: February 16, 2013, 08:43:15 am »
     Truck is coming along great.  I always thought it would be great to make one of these into a short bed 4x4 and raise it up a bit.
Offline rhino
« Reply #57 on: February 18, 2013, 10:48:05 am »
The sealer & base coat all kinda look the same in these shots, but you defiantly can tell when the clear is put on.
the next day out side
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #58 on: February 18, 2013, 11:04:45 am »
Looks great! Are you using an hvlp gun?
« Reply #59 on: February 18, 2013, 01:14:46 pm »
Nice progress!  I am jealous...
