Author Topic: 454 Build  (Read 3081 times)
Offline Bigred85
454 Build
« on: January 28, 2013, 06:00:47 pm »
 I have an 84 c30 454 crew cab, going to slowly build a 454 to pull with. I can get these for $150 Block. 3999289, Heads 353049, any thoughts. Please tell me if I should pass it up.
Offline Tx_Phil
454 Build
« Reply #1 on: January 28, 2013, 08:22:59 pm »
Wish I could help but I'm sure someone on here will chime in soon.
Re: 454 Build
« Reply #2 on: January 29, 2013, 01:43:04 pm »
049 heads are good for the cast versions.  Any BBC block is fine, the Gen V are usually skipped over, but can be made to work if you all you are doing is making a puller or street motor.
