Author Topic: th400 not shifting soon enough  (Read 4378 times)
Offline flips87c30
« on: January 28, 2013, 06:05:05 pm »
I have an 87 v30 with a 454 and a th400. the issue is when going from first gear to second it seems to shift late. it revs too high then shifts kinda hard. Not as bad when going from second to third. I looked under the truck and noticed that the modulator line is not hooked up to the modulator valve(broken rubber piece). Is this my problem or should I be looking for something else?   Thanks in advance
87 v30 duelly dump truck 454, th400, np205, dana 60/14 bolt, warn hubs, gmt800 mirrors and LEDs all around the bed.
Offline Sartobuilt
Re: th400 not shifting soon enough
« Reply #1 on: January 28, 2013, 07:32:59 pm »
Yes, that should fix it. Might want to replace the hose, they get squishy from trans fluid.
Offline flips87c30
« Reply #2 on: January 28, 2013, 07:39:55 pm »
Thanks I live about 45 minutes from the nearest autoparts place. Just wanted to make sure there wasnt something I was overlooking before I made the drive.
« Reply #3 on: January 28, 2013, 08:14:04 pm »
If there is evidence of any trans fluid oozing from the nipple of the modulator valve, replace the modulator valve and install a new vacuum hose.
Offline Engineer
« Reply #4 on: January 29, 2013, 08:30:07 pm »
I'll ditto both of these posts.
If your modulator valve has a broken diaphragm (leaking fluid) make sure you match the color bands on the out side of the valve when buying a replacement.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline DnStClr
« Reply #5 on: February 07, 2013, 09:53:57 am »
And, don't forget, expect trans fluid to come out when you replace the valve!
Don
87 Chevy Silverado
