Author Topic: manual or electric doors  (Read 5403 times)
Offline Low82C10
« on: February 04, 2013, 09:01:27 pm »
i had a set of electric doors, i thought i wanted to kinda stick to a classic and keep the manual doors, so i got rid of my spare doors. now im kinda regretting it and want electric windows and locks, how hard is it to run power to them etc? is it really worth it do they have problems?
Re: manual or electric doors
« Reply #1 on: February 05, 2013, 08:28:33 am »
     The easiest way is to take the harness out of a donor truck, but can be done by wiring them off a diagram also.
     If you are asking if they have more problems than the manual windows ?  My answer is yes.  Anything electronic will have more problems than something of the same that is manual, that is the price we pay for convenience.
     But if you make sure to go through the electric windows and clean and lube everything from the start, they should give you years of trouble free service.
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #2 on: February 05, 2013, 12:47:38 pm »
I converted my crewcab to electric, wow that took some time, however i adjusted and cleaned everything.Make sure you fasten all the wires in the door correctly as I had a plastic keeper clip break and allowed the power wire to rub on bare metal.
Offline rhino
« Reply #3 on: February 06, 2013, 09:36:32 am »
I did the same thing as pholliday1 did. Power windows and locks. I got a harness from another forum member and went at it. It wasn't as bad as i thought it would be. but it still was a pain. Iv also added keyless entry  still trying to tweek that.
« Reply #4 on: February 18, 2013, 10:09:47 pm »
The doors themselves are exactly the same, it is the regulators that are different along with the motor and wiring.
I sell both in the store and they are the same as factory and come from Electric Life:
Window kit:
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=GM01-K&Category_Code=7T
Switch kit:
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=4990-10-356&Category_Code=6T
Offline pcguysam
  • Total N00B
« Reply #5 on: June 12, 2013, 04:49:42 pm »
I see that this is for power windows.  Does it not include power locks or am I missing something?  Is there a separate power lock kit available?
81 C10 Custom Deluxe Stepside Purchased 2/2013
