Members Rides
My 85 Chevy (Big Blue)
Topic: My 85 Chevy (Big Blue) (Read 9464 times)
pedigo78
Big Blue
February 11, 2013, 11:20:18 pm »
Here is look at my Big Blue, has been back home in Temple Texas for over a year while I trained and deployed. Finally today my dad sent me a picture of it loaded up on the truck getting ready to head to Oceanside Californa to be with me again.
Sgt Pedigo USMC
pholliday1
1990 V3500 Crew Cab
Re: My 85 Chevy (Big Blue)
February 12, 2013, 07:50:16 am »
Wow, I can't even imagine how excited you are.. Good for you!
bake74
February 13, 2013, 08:20:09 am »
You should have some fun in Oceanside with that truck.
74 k10, 77k10 Tom
pedigo78
Big Blue
February 13, 2013, 11:01:17 pm »
Yeah it will be nice to drive, to bad when it got here i found a mountain of leaks that need fixing
Sgt Pedigo USMC
pholliday1
1990 V3500 Crew Cab
February 14, 2013, 07:26:01 am »
Gaskets are cheap and so is your labor, start attacking them one at a time and you'll get her tightened up.
rhino
February 14, 2013, 07:34:22 am »
very nice
My 88 Crew cab build thread.
pedigo78
Big Blue
February 15, 2013, 10:21:08 pm »
Thanks yeah, I going to start taking care of them
Sgt Pedigo USMC
pedigo78
Big Blue
March 02, 2013, 04:29:56 pm »
Well tightened down then oil pan bolts, and tranny pan bolts sense rebuild, all bolts on oil pan where loose. hopefully that takes care of leaky pan. as for the tranny pan most were tight, so could be from the servo seals or dipstick seal.
Sgt Pedigo USMC
pedigo78
Big Blue
March 08, 2013, 07:41:35 pm »
Well went for a ride after tightening down the oil pan bolts. and the loosened up again. so I am going to put lock tight on then and re tighten. should take care of the leaking pan.
Sgt Pedigo USMC
bake74
March 09, 2013, 09:16:21 am »
Lock tight should work, if not use small lock washers.
74 k10, 77k10 Tom
pedigo78
Big Blue
March 09, 2013, 05:57:33 pm »
All oil pan bolts removed and applied lock tight and lock washers (good idea Bake) when for a nice ride and went to check and still nice and tight. although still a leak from the back. I thought it was the rear main but I shined a flash light up from the bottom and noticed the rear of the passenger valve cover looks like it leaking and running down the block on the starter. Replace that and hopes that the last of it.
Sgt Pedigo USMC
bake74
March 09, 2013, 07:00:33 pm »
You know once you get all these leaks fixed, at least you will know what has new gaskets, if there is a next time you know what should not be leaking.
74 k10, 77k10 Tom
Members Rides
