Author Topic: Transfer case problem  (Read 10728 times)
Offline 83chevycustom
« on: February 13, 2013, 09:24:11 pm »
Im not for sure what transfer case this is, but I know the most forward gear is 4L. But the 2 gears in the middle doesn't work. Ill put the truck in gear and just hear something start to spin. Anyway to identify the transfer case?
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Transfer case problem
« Reply #1 on: February 14, 2013, 07:30:45 am »
Post a picture
« Reply #2 on: February 14, 2013, 08:11:10 am »
If low is all the way forward its not a 208.
Easiest way to tell a 203 from a 205 is the shifter.
205 The shifter is mounted with a single bolt to the transfer case / transmission adaptor. It pivots on this bolt when shifted back, and forth. Allot of times the bolt head will have a grease fitting in it.
203 Has a shifter assembly like a GM 4 speed transmission.
« Reply #3 on: February 14, 2013, 09:33:23 am »
Alright, thanks for the information ill take a look at that today, and try to get a picture of it.
Offline Cabcorner
« Reply #4 on: February 15, 2013, 06:33:16 am »
                      Could this be yet another case of the classic 203 with lockouts or a missing front drive shaft ?
Offline Jason S
« Reply #5 on: February 15, 2013, 08:04:35 pm »
If the truck is an '83 (I presume an '83 Chevy K10 or K20 Custom Deluxe) and the most forward position is 4L, it is most likely a NP208.
If in doubt, look under the truck at the t-case.  If the t-case is all aluminum, then it again should be a NP208.  If it is cast iron, it could be the NP205 or NP203. Following what Blazin said, look at the shifter or post a photo like pholliday1 said.
Offline frotosride
    • WFO CONCEPTS
« Reply #6 on: February 15, 2013, 09:20:30 pm »
That is almost hilarious and I'd like to say that I'd notice a missing front drive shaft but now a days I have a hard time remembering my own name so I wouldn't put it past me to over look something that should be so obvious.
Offline frotosride
    • WFO CONCEPTS
« Reply #7 on: February 15, 2013, 09:22:23 pm »
Oh and while you are under there look at the back of the case there should be a round tag with red writing on it. That's the ID tag it will tell you exactly what you have...if it's still there.
« Reply #8 on: February 15, 2013, 10:18:34 pm »
The most forward shifter position on all my 208s is 2 wheel drive, back one is 4 high, over to the right a bit back one more is neutral, and all the way back is 4 low.
