Author Topic: Initial Timing Issue (a quest for better fuel mileage)  (Read 32533 times)
Offline Fairlane514
Re: Initial Timing Issue (a quest for better fuel mileage)
« Reply #15 on: April 24, 2013, 09:03:06 am »
Actually you turn the distributor counterclockwise to advance it.
Offline 81_Chevy
« Reply #16 on: April 24, 2013, 09:50:58 am »
so (since my timing tab is the wrong one) i would turn the distributor counterclockwise until i head pinging, and then turn it clockwise until i get the highest vaccum reading? something like that?
Offline 79gmc15
Re: Re: Initial Timing Issue (a quest for better fuel mileage)
« Reply #17 on: April 24, 2013, 12:24:12 pm »
Riiigghhhtt... haha thank you!
Offline 79gmc15
« Reply #18 on: April 24, 2013, 12:31:25 pm »
What I did was adjust to highest vacuum, go for a drive (up hills, full throttle starts, etcetera)  and listened for pinging and back it off accordingly. I found that my truck ran really great advanced(lots more power and response) but pinged under load. So maybe when I am rich I'll run mid or premium gas to rid of the ping. Lol make sure you use your normal gas too. Different qualities of gas can effect results.
Offline 81_Chevy
« Reply #19 on: April 24, 2013, 02:38:50 pm »
thanks 79!
one more question, if i were looking at the front of the engine, about where would the plugs(where the wires plug into the coil on the cap) on the dist be at if i were in the ball park of the right timing? mine right now is about 3oclock ish
« Reply #20 on: April 24, 2013, 06:57:39 pm »
The old school dial in works something like this. You would incrementally advance the timing and go for a ride. If at any time under load it starts to ping you've gone too far. Conversely it should start easily without straining the starter. Once you find where you have the best performance record your readings and fine tune, adjust idle speed etc. It's OK to play around with it.
Offline Fairlane514
« Reply #21 on: May 01, 2013, 09:15:05 pm »
Whats wrong with your timing pointer?
« Reply #22 on: May 01, 2013, 10:06:43 pm »
OJT !   :)
Offline Fairlane514
« Reply #23 on: May 01, 2013, 10:22:40 pm »
Maybe I missed something in the posts, but why don't you get the correct timing pointer and set the timing properly?
Offline 81_Chevy
« Reply #24 on: May 02, 2013, 07:14:38 am »
it turned out that i was putting the timing light plug on the #2 cylinder and not the #1 lol  :o  :P
Offline Fairlane514
« Reply #25 on: May 02, 2013, 08:40:14 am »
Ok, so now that you know which is the number one cylinder, hook up your timing light and see where you are. Try 10-12 degrees advanced (vacuum disconnected and plugged) that should be safe.
Offline 81_Chevy
« Reply #26 on: May 02, 2013, 11:41:16 am »
i set it at 8* for now, thats what my Chilton's manual said lol. in a couple weeks ill set it to 6* and see where it goes and then ill start going back the other way up to 10* and 12* and see where the best performance is! (gas mileage lol)
-Nic
Offline 79gmc15
« Reply #27 on: May 02, 2013, 02:27:58 pm »
-Nic
I wouldn't bother with 6*. The more retarded the number the likelihood that you'll get worse gas mileage, the whole reason for the 10* is emissions not MPG.  Your motor will be more efficient more advance and therefore better MPG.
Offline 81_Chevy
« Reply #28 on: May 02, 2013, 09:33:40 pm »
hmm alright thanks 79! i will have to change my timing up to 10* then when i get back this weekend! thanks for the advice!  8)
Offline 79gmc15
« Reply #29 on: May 02, 2013, 11:19:28 pm »
I've read that what you want is be fully advanced @32* by x rpms. I've seen people saying it's best to be "all in" by 3000 rpm. That includes your initial plus vacuum. I am sure ill be corrected if I am wrong.
