Author Topic: Rusty Cab Corners  (Read 14115 times)
Offline 83dualtone
    • Chevy C10
Rusty Cab Corners
« on: February 20, 2013, 12:25:41 pm »
Does anyone know why '80 model C10's commonly have rusty cab corners? I'm going to replace the sheet metal but was hoping to figure out how the water accumulates there so I can do some preventative maintenance before it happens again.
The truck is an '83 C10
Any info is appreciated.
Here's a couple of pics I took this morning:
Re: Rusty Cab Corners
« Reply #1 on: February 20, 2013, 09:15:46 pm »
Its a tight spot between the inner, and outer cab corners. It is prone to rust because it gets dust and dirt built up over the years. That attracts moisture.
Offline 83dualtone
    • Chevy C10
« Reply #2 on: February 21, 2013, 10:49:56 am »
Thanks Blazin :)
Offline Engineer
« Reply #3 on: February 23, 2013, 12:55:28 pm »
Also consider the fact that our trucks didn't have galvanized body panels.
When replacing the cab corners, rocker panels, floor boards, cab mounts, etc. you should consider stripping the black primer from the replacement parts then prime inside, and out with a good epoxy primer.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline hondarider188
« Reply #4 on: February 24, 2013, 12:30:40 am »
sorry i cant really contribute to the actual question but i have rust in the exact same place on my 83' k10. so would i need to order a cab corner or extended cab corner or is it something else?
1983 K10 silverado
Offline Donut
« Reply #5 on: February 24, 2013, 11:52:08 am »
Look and see how far the rust goes.
Cab corners are 2 different sizes, sm and large depending how much you have to replace.  Also check the inner cab corner and rockers to see how bad they are.  Capt. should have everything you need.
I also have a couple to replace, just need time and a new welder first. (and of course $$ to do it)
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
« Reply #6 on: February 24, 2013, 08:24:06 pm »
im not sure on how far down the rust is on the cab corner. so if you have the specs. on the new corner replacements such as the length so i know which one i need. and i do think i need to replace my rocker panel anyway. i think i will start my one post on this so im not just taking up 83dueltone's thread. so please watch for it and get back to me.
1983 K10 silverado
Offline 83dualtone
    • Chevy C10
« Reply #7 on: February 27, 2013, 09:11:57 am »
Thanks guys. I did see the cab corner replacements. I'll definitely prime both sides before I weld them in.
« Last Edit: February 27, 2013, 11:10:23 am by bd »
Offline Remon.
« Reply #8 on: March 01, 2013, 03:47:23 am »
Ok. But where is the dust and dirt coming from? Should be from inside the cab right?
Also, the cap (on the backside of the cab corner, under the cab) is to high placed to get dirt and especially water out. I sprayed the inside of the cab corners with special hollow spaces wax, but it didn't come out anywhere. Not even out of the hole of the cap and I sprayed in a lot.
Offline Elpresidente
« Reply #9 on: March 01, 2013, 02:01:49 pm »
I did mine 2 years ago, and i'll tell you don't bother with inner cab corners. Yes, they are supposed to keep water and dirt out of the cab (theres a small opening behind the seat behind the door jamb) but really all they do is create a terrible spot for rust. I cut mine off and left them out, welded up that opening behind the door jamb, and now I can clean that spot out frequently since its bad for collecting dirt.
'82 Chev Scottsdale
Proud to be Canadian \m/
