Author Topic: Big ol' sway bars  (Read 9757 times)
Offline Elpresidente
Big ol' sway bars
« on: February 22, 2013, 08:22:40 am »
Is a sway bar from a 1-ton truck too heavy to put on a 1/2 ton truck? My concern is if the front end becomes too stiff, it may damage the frame over time. Just asking because the local scrapyard has a few 1-ton work trucks, and my truck lacks a sway bar.
'82 Chev Scottsdale
Proud to be Canadian \m/
Re: Big ol' sway bars
« Reply #1 on: February 22, 2013, 02:01:23 pm »
Not going to hurt it at all.  Several have upgraded to a one.
« Reply #2 on: February 22, 2013, 04:46:33 pm »
I see. would you say it's a good upgrade worth doing?
'82 Chev Scottsdale
« Reply #3 on: February 22, 2013, 05:32:05 pm »
Before I joined this forum I did it to a half ton and it worked out great for handling.  I am going to make that upgrade on my 86 C10 and also install the rear one off my 1 ton dually.  If anything it would look neat but hoping it will corner real well going around clover leafs.
Offline 79gmc15
Re: Re: Big ol' sway bars
« Reply #4 on: February 23, 2013, 12:36:38 am »
It's one of the cheapest mods with the biggest change you can do to your truck. :D
« Reply #5 on: February 23, 2013, 12:51:18 pm »
Excellent, just picked it up and i'll install it soon.
'82 Chev Scottsdale
Offline Rich84
« Reply #6 on: February 25, 2013, 09:48:23 am »
Are the brackets riveted or bolted??
Offline Tx Firefighter
Big ol' sway bars
« Reply #7 on: February 25, 2013, 11:34:36 am »
They are riveted.
Offline 79gmc15
« Reply #8 on: February 25, 2013, 11:37:39 am »
The frame stands are the only things riveted.
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #9 on: February 25, 2013, 05:06:13 pm »
Also if funds allow look into using polyurethane the oem rubber leaves a lot to be desired it breaks down over time
Offline N2TRUX
« Reply #10 on: March 11, 2013, 09:52:38 pm »
I have to politely disagree with you on using polyurethane bushings over quality rubber parts. The larger bar is an awesome upgrade, but adding poly bushings will make you crazy with them squeaking. If you want better than stock rubber, consider poly-graphite instead. Its is naturally lubricated and wont squeak.
