Author Topic: Where does this wire go?  (Read 4399 times)
Offline Harmon
« on: February 23, 2013, 11:18:08 pm »
This wire is on the drivers side under the hood, and has a long wire to the connector.  My truck is a 86 chevy that originaly came with a 305.
I do not have awire diagram and am trying to put back wires where they go as a few are not connected to anything.
Thank you.
Re: Where does this wire go?
« Reply #1 on: February 24, 2013, 12:16:53 am »
Does that wire become "green" as you trace it back toward the firewall?  It looks like oil and heat have beaten it up a little bit.  If it's the 'green' wire next to your hand, it probably connects to the water temperature sender for the dash gauge.
Look through the 81-87 wiring diagrams in our Technical Pages.
Offline 81_Chevy
« Reply #2 on: February 26, 2013, 01:46:08 pm »
looks like the temp guage sensor
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #3 on: February 26, 2013, 02:53:07 pm »
x2 Temp sensor should be by drivers exhaust manifold
Offline 77gmc
« Reply #4 on: March 04, 2013, 01:03:22 pm »
I once had a 1985 very plain K10.   It had empty plugs all over the place for unused options.  I see there are wiring diagrams in the reference section here
