Author Topic: Bent tie rod end mistery  (Read 6035 times)
Offline 82BlazerMan
    • Blazer pics
« on: February 24, 2013, 10:12:52 pm »
1982
K5 Blazer
2WD
Hey Guys,
About 5 years ago I lowered my Blazer by removing about a 1/2 a coil from my front springs.  At the same time I rebuilt my front end replaced ball joints, tie rod ends rubber stuff etc...  Anyway, about 2 years ago I noticed that both tie rod ends were bowing backwards.  I've lowered the same type of truck front end, only it was a C10 and I never noticed this.  Could I have put something on wrong?  At one point while putting the long bar in the middle (tie rods attach to it) I thought I had put it on wrong, so I reversed it.  It seemed to be the same either way.  Could I have put it on wrong?  At any rate, why would the tie rod ends be bowing?  I'm probably going to rebuild the front end again, but I definately don't want to do it wrong again if that's the case.
1982 Blazer 2WD
305ci
700R4
Re: Bent tie rod end mistery
« Reply #1 on: February 26, 2013, 04:25:11 pm »
Pictures of what you mean by "bowing"?
Offline 82BlazerMan
    • Blazer pics
« Reply #2 on: March 10, 2013, 05:26:26 pm »
Here's a few pics.  Hope these links work.
1982 Blazer 2WD
305ci
700R4
« Reply #3 on: March 10, 2013, 10:58:10 pm »
     How much or the threads are left on the tie rod ends ?
Offline 82BlazerMan
    • Blazer pics
« Reply #4 on: March 10, 2013, 11:18:24 pm »
2, 2 1/2"
1982 Blazer 2WD
305ci
700R4
« Reply #5 on: March 12, 2013, 01:16:14 pm »
Wow, that is way out there on the threads...
« Reply #6 on: March 12, 2013, 09:30:42 pm »
     Are you saying 2 - 2 1/2" left inside the sleeve, or outside the sleeve ?  I agree with Capt.  After looking at both my trucks, it seems like there is a lot of threads outside the sleeve.
Offline 82BlazerMan
    • Blazer pics
« Reply #7 on: March 12, 2013, 11:07:08 pm »
2, 2-1/2" inside the sleeve
1982 Blazer 2WD
305ci
700R4
