Author Topic: suburban steering column help needed....  (Read 7111 times)
Offline piston383
« on: February 27, 2013, 11:38:00 pm »
Hi everyone, I've got a small problem I was hoping I can find some help woth. I have an 88 suburban with a tikt column. The column was loose (typical tilt bolts backing out) so I was in the process of taking it apart when I broke off my pivot pin remover inside one of the pins (driver side). Is there a way to get the broken piece out without destroying the pin itself?
Re: suburban steering column help needed....
« Reply #1 on: February 28, 2013, 02:09:37 pm »
You broke the tool off in the pin?  That is a tiny bolt, did you get it out or is the pin still in?  I don't know of a ez out that small.
« Reply #2 on: February 28, 2013, 03:38:42 pm »
Did it break off flush?  Recoil makes a small screw extractor kit that might work (4507P), but it costs about $50.
