Author Topic: Suspension Problem or something else???  (Read 6354 times)
Offline Low82C10
« on: February 28, 2013, 12:47:04 pm »
i have a 82 c10 shortbed, it has never had this problem till after i towed it on a flat bed trailer. i loaded it on a flat bed and it was center of the trailer, when i arrived to the shop, the truck was all the way to the front of the trailer which it moved two feet foward. i didnt really think any thing of it, yesterday i test drove it after the exhaust shop finished up my exhaust and i makes like a clunking noise when i turn left. what should i check out? it drives fine everything else seems ok but just when i turn left it clunks and it goes away a few seconds after driving straight.
Re: Suspension Problem or something else???
« Reply #1 on: February 28, 2013, 01:48:25 pm »
Why was it being towed?  Did something happen?  Have you inspected the front?
Offline Low82C10
« Reply #2 on: February 28, 2013, 03:31:15 pm »
i just got done with my ls swap and have my exhuast so it got towed to get my whole exhaust done, i have not inspected it yet. where should i start
« Reply #3 on: February 28, 2013, 09:18:55 pm »
do you have to be going fast for it to happen, if not have someone stand beside the truck and see if they can pinpoint where it is coming from.
Otherwise check all your suspension components.
Offline Low82C10
« Reply #4 on: March 01, 2013, 10:24:16 am »
no, just rolling it does it. i pick it up today but i will get it towed again since i dont have my bed and my tail lights on and plus something is up with the tune of the truck :/   ill see if he can put it on the lift before i leave
« Reply #5 on: March 01, 2013, 10:33:21 pm »
     How was it hooked up to the trailer ?  Chains or straps.  I would start looking where the tie down points were. ( did you use the front axle or something else in front to secure to trailer ? )
Offline frotosride
    • WFO CONCEPTS
« Reply #6 on: March 06, 2013, 07:52:52 pm »
Very good point. something may have been accidently bent because it wasn't as strong as whoever strapped it down thought. This would explain the movement on the trailer as well.
« Reply #7 on: March 09, 2013, 10:05:45 am »
     I have towed a lot of things in my life, and have seen the results of not connecting to the proper tie down points.  Things can get messed up really quick if not properly secured.
