Author Topic: Rear gear ratio for mileage  (Read 7961 times)
Offline Enginerd
« on: March 01, 2013, 04:34:46 pm »
Hi guys,
I have a 1978 C-10 with a 350 SBC, SM465 tranny, and 3.73 geared 12-bolt.  Would swapping to a 3.08 rear gear (or numerically lower) help my mileage much?
Thanks,
Gary
Re: Rear gear ratio for mileage
« Reply #1 on: March 01, 2013, 05:18:43 pm »
If you do mostly highway driving yes, but otherwise probably not.  What is your current usage and mpg?
Offline Stewart G Griffin
« Reply #2 on: March 02, 2013, 12:50:43 am »
i think so---for highway cruising.  And it would likely improve more with 2.73.
Might be cheaper/easier to go with taller tires.
Offline Enginerd
« Reply #3 on: March 02, 2013, 01:11:58 pm »
I live in a rural area where most of the drive time is used to get to town, and then just a short distance through a small town.  I'm not sure what the current mpg is since my odometer is not working
I think so---for highway cruising.  And it would likely improve more with 2.73.  Might be cheaper/easier to go with taller tires.
I'd really like a set of 2.73 gears, but I cant buy 2-series gears new.  I'd also be happy with a set of 3.08 gears, which I can buy new, but I think I need a different carrier to use them, wouldn't I?  As for tires, I just bought all new stock size tires for the factory rims, so I don't want to get new rears again.
« Reply #4 on: March 02, 2013, 01:36:21 pm »
I would trade you in a heartbeat if you were anywhere close to NW Indiana.  3.73 is a perfect gear using a OD.  IMO your best bet would be to find a whole rear end and swap it out.
Offline travisr1988
« Reply #5 on: March 02, 2013, 09:10:14 pm »
Wouldn't taller tires just throw off your odometer and speedometer? which really wouldn't help your mileage, it'd just make you think it is, a narrower tire will help a little, but I don't think a taller tire would help. Anyone care to explain the taller tire theory?
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
Offline Tx_Phil
« Reply #6 on: March 02, 2013, 11:14:25 pm »
Taller tires equate to a numerically lower final drive ratio. The taller the tire the fewer times it needs to turn to cover the same distance as a short tire. This results in fewer RPMs and less fuel consumed.
The trade off is that you now have a longer lever arm thus taking more energy to get the tire turning. In this case taller tires cost you more gas.
If you drive 50/50 hwy/city taller tires will typically burn more gas. If you drive 75% hwy then they can save you a little gas.
Offline travisr1988
« Reply #7 on: March 03, 2013, 02:50:33 pm »
That makes sense. Thank you for the explaination Tx_Phil
Offline Tx_Phil
« Reply #8 on: March 06, 2013, 07:01:07 pm »
Glad I could pitch in.
I'm a computer geek more or less so my wrenching skill aren't really good enough to help out around here. When I do stumble across something I know the answer to I try to help.
« Reply #9 on: March 07, 2013, 07:31:31 am »
Based on what you explained as your driving habits in my opinion it would take you a long time to pay yourself back with the next to nothing increase in MPGs you will see of the cost of swapping gears, or even the whole axle.
Offline Boone83K10
« Reply #10 on: March 07, 2013, 10:30:21 am »
I have the same type of driving you have, except mine is in the mountains of NC. I have 3.08 auto hub 10 bolts with 700r4... I am only getting 7 mpg (average). I don't think the swap would be worth it.
1966 Mercury Comet - Built 429 (First Car/Show Car)
1983 Chevrolet K10 - Built 350 (Winter Toy)
1992 Chevrolet Lumina Euro (Sold @ 265,000 miles)
2003 Ford Escape 4x4 - Mac Perf. Intake/Exhaust (Wifes' DD)
2007 Mercury Milan - Steeda Tuned (Summer Toy)
