Author Topic: C65 cab on c20?  (Read 5047 times)
Offline travisr1988
C65 cab on c20?
« on: March 07, 2013, 06:04:39 pm »
I always loved the small back windows and our body style only had them in the bigger trucks, so I want to drop a cab from a bigger truck with the small window onto my frame. Is it possible? what mods will I have to do? Has it been done before? anyone have pics if so?
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
Offline thirsty
    • Suitor's Garage
Re: C65 cab on c20?
« Reply #1 on: March 07, 2013, 06:09:39 pm »
The cab corner area is quite a bit different I know. I'm not sure what else is different. I entertained the thought when I was looking for a donor cab.
Offline HAULIN IT
Re: C65 cab on c20?
« Reply #2 on: March 07, 2013, 08:29:07 pm »
I don't recall anything different with the cab corners, but the floor & lower firewall are for sure. I would think more about swapping the back panel onto a regular cab would be a better plan if your set on the look. My Two Cents, Lorne
Offline thirsty
    • Suitor's Garage
Re: C65 cab on c20?
« Reply #3 on: March 08, 2013, 05:46:46 am »
Re: C65 cab on c20?
« Reply #4 on: March 09, 2013, 10:13:18 am »
     I agree with Lorne, would be easier to cut the small window out and graft it onto another cab.
Offline HAULIN IT
Re: C65 cab on c20?
« Reply #5 on: March 09, 2013, 09:25:05 pm »
Here is a past discussion on this.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=18611.0
Oh yea, I forgot about the back area, however I still think the whole back panel is doable if someone wanted to. If you look @ the back of a regular cab...just below the spotwelds that attach the rear crossmember/floor, the panel rolls in slightly & then is cut off. It appears to me that all you would need to do is cut off the "skirt" area of the C60 into the same shape the right along the strengthening rib shown in your photo of the C60 which would then be the same as a reg. cab & weld it on the the regular cab crossmember/floor. Lorne
