Author Topic: Rear axle stamp location  (Read 2995 times)
Offline blublazn86
« on: March 08, 2013, 12:24:34 pm »
Hello,  I have an 87 R10 Silverado 2wd and I'm trying to find out where the axle stamp location is located.  Any and all help will be greatly appreciated.   Thanks
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Rear axle stamp location
« Reply #1 on: March 08, 2013, 12:38:42 pm »
What specifically are you looking for? If it's gear ratio i would suggest pulling the diff cover. That's the only real way to get accurate info ,plus if its like most of our trucks it could stand a change.
Offline blublazn86
« Reply #2 on: March 08, 2013, 12:50:25 pm »
I did that and I came up with a 2:73 ratio.   I was just curious if that is what it came with since there was no rpo tag in the glove box.
Offline pholliday1
« Reply #3 on: March 08, 2013, 02:34:02 pm »
My best guess is yes and here's why. Very few and far between are you going to find "someone" "Swapping" in 2:73's for rear end gears. Can it happen? Yes.. but not very likely..
