Author Topic: 1984 C30 Cab and Chassis  (Read 16988 times)
« on: March 09, 2013, 06:16:42 pm »
Worked all day last Saturday getting the bed loose.  Today my brother came over with his son and between 4 of us we got her off.  It is due to go bye bye first thing Tuesday morning.  Now I need to drill 6 holes in the frame on top so a regular box will bolt to it.  I guess cab and chassis trucks did not have the holes stamped for some reason...  Next up is to un-duallyize my crew cab and transfer all the stuff to this one, stay tuned.
Re: 1984 C30 Cab and Chassis
« Reply #1 on: March 09, 2013, 06:27:37 pm »
     Great start.  What are your plans for the truck Zieg ?
« Reply #2 on: March 09, 2013, 09:05:05 pm »
Just make it a decent looking dually that is a worker...
« Reply #3 on: March 10, 2013, 01:30:19 am »
     So do you have the axle and bed or do you need to source them ?
« Reply #4 on: March 10, 2013, 07:56:07 am »
I have everything I need off my crew cab dually.
1984 C30 worker
« Reply #5 on: September 07, 2013, 05:27:15 pm »
Been busy getting a pickup going so I can use it.  Since no one was in the market for a single wheel cab and chassis I put the 85 bed on it, rear bumper, hitch and rear seat from the 87 Crew cab.  I have 2 more matching tires like the rear to put on but she is road worthy.  There is a larger than normal gap between the bed and cab that I am thinking about clamping some 4" PVC capped at the bottom for shovels and brooms.
Re: 1984 C30 worker
« Reply #6 on: September 07, 2013, 10:18:14 pm »
     That is the one that came with the utility bed right ?  Are you completing it and making it run to see or keep ?
Re: 1984 C30 worker
« Reply #7 on: September 07, 2013, 10:26:03 pm »
Yes it came with the utility bed on it.  I will use it until my 85 C20 is back on the road.  It runs fantastic and costs a whopping $162 per 6 months to insure it.
Offline Stewart G Griffin
Re: 1984 C30 worker
« Reply #8 on: September 08, 2013, 11:27:03 am »
i forgot how much i paid, but it's either $191.67 or $224 for 6 months with state farm.  A 1/2 ton.
Offline blazing816
Re: 1984 C30 worker
« Reply #9 on: September 09, 2013, 08:15:46 am »
The other thing you could do (I know its temp until your c20 is done) But you could fab up a custom metal "headache rack" that could have mounts for tools and you could put lights on the top so you could light up whatever you are doing. And you could make it mount to front of bed or down to frame and that could fill the gap.
Re: 1984 C30 worker
« Reply #10 on: September 22, 2013, 06:07:06 pm »
Well I got to digging around and found my last 16 conversion lug nuts so I could put the new front tires on and take it for a spin.  Even though the idler arm needs replaced it goes on down the road straight.  I am very pleased with it so far.  Only 1 license plate light is out, everything else works as it should.
Re: 1984 C30 worker
« Reply #11 on: September 22, 2013, 07:21:41 pm »
I had to share, got a love running lights...
