Author Topic: gas smell on '94 tbi  (Read 3279 times)
Offline the_legend_1981
« on: March 19, 2013, 05:53:07 pm »
I got the truck up to around 80 yesterday on the highway and smelled a gas odor coming in through the vents. Did not notice it at 65. No visible leaks anywhere. Has anyone had similar issues?
Offline Engineer
Re: gas smell on '94 tbi
« Reply #1 on: March 19, 2013, 07:27:42 pm »
I have a '94 K2500 that smells like that after I drive it. I never thought too much about it, I assumed it has to do with the evap canister getting old.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #2 on: March 19, 2013, 07:30:41 pm »
I suspect the same thing as Engineer.  Although there's no correlation to vehicle speed with the following, perform an inspection of the vapor canister along with all the fuel and vapor hoses all the way back to the tank(s), including the tank selector valve if present, and connections.  If the canister weighs more than about 3 lbs, it's beginning to saturate - more than ~5 lbs, replace it.
« Reply #3 on: March 21, 2013, 09:09:41 pm »
Thanks for the info. I will check that out
