Author Topic: 14bsf to 14bff swap?  (Read 6299 times)
Offline csdineley
« on: March 25, 2013, 11:16:46 am »
Hello
I wondering how hard would it be to swap a 14bff into my truck with a 14bsf?
1987 V20 Custom Deluxe, Vortec Headed 350, SM465,Np205 14Bff 4.10
Re: 14bsf to 14bff swap?
« Reply #1 on: March 25, 2013, 01:11:34 pm »
If it is an early model regular cab it will bolt right in.  What is the donor?
Offline csdineley
« Reply #2 on: March 25, 2013, 01:18:39 pm »
1986 GMC 1-ton srw. Everything looks like it would bolt up but the shock mounts.
« Reply #3 on: March 25, 2013, 02:12:10 pm »
It will bolt in. Shock mounts might need to be modified, or swapped from the semi floater. U joint might have to have a combonation joint.
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #4 on: March 25, 2013, 03:32:03 pm »
That's a huge upgrade you'll be glad you did.
Offline Engineer
« Reply #5 on: March 25, 2013, 10:26:13 pm »
NO!
If the 14-bolt FF is out of a 1-ton the spring seats are narrower than your 3/4-ton. You need to find a 14-bolt FF from a 3/4-ton, or be prepared to cut and reweld the new axle's spring seats.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
