Author Topic: big block install  (Read 4522 times)
Offline dirtracer55
big block install
« on: March 27, 2013, 07:50:00 am »
I am in the middle of a swap from a small b lock to a BBC in my c-10, the only problem that I'm seeing is the power brake booster being in the way for any valve train adjustments with out removing the entire booster. Any thoughts would be helpful.
Offline Engineer
Re: big block install
« Reply #1 on: March 27, 2013, 10:10:19 am »
I never had that problem. It is tight, a pain to get the valve cover off, but it is doable.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline dirtracer55
« Reply #2 on: March 27, 2013, 10:39:00 am »
even with tall valve covers? Have a roller cam and stud girdles so its a pain but it can be done?
Offline Engineer
« Reply #3 on: March 28, 2013, 08:35:01 pm »
I have tall valve covers, and roller rockers, but no stud girdle.
The stud girdle may be the game changer.
Offline Nthefamily
« Reply #4 on: November 01, 2013, 10:08:10 am »
I have the same issue with my '85 k10.
Engineer, what valve covers did you use? I do not have girdles.
The slanted cast aluminum from Summit will fit, but do not have baffles.
Offline Engineer
« Reply #5 on: November 02, 2013, 09:29:47 am »
I have some plain tall chrome stamped steel valve covers that I bought from Jegs.
They are the cheapest valve covers in the catalog, but are made from pretty heavy steel. Probably 18ga or heavier. They do have baffles. After a while they rusted, so I sandblasted the chrome off, and repainted them with the hammered finish Rust Oleum paint in silver. They look pretty good.
Never had aluminum covers on this engine so I don't know how they will fit.
Offline Nthefamily
« Reply #6 on: November 02, 2013, 06:20:08 pm »
Bought a set of GM Performance cast aluminum valve covers (part # 25534374) today from Summit and they fit great. Have holes for breathers and had baffles, unlike what the website says. Now time to finish putting his hoss back together and see if she'll crank.
