Author Topic: 1974 C10 Stepside Shackle removal  (Read 5272 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: March 29, 2013, 07:14:43 pm »
I am replacing worn out springs and shackles.  The shackle bolt won't clear the fender.  Is it permissible to cut off the shackle bolt and install a new one the other way through where there is clearance?  Seems like the logical thing to do but maybe someone knows a reason why not??  Thanks for any input.
Ricky
Ricky
Re: 1974 C10 Stepside Shackle removal
« Reply #1 on: March 31, 2013, 10:21:13 pm »
It doesn't matter wich direction the bolt goes.
I for the life of me can't figure out how the fender would interfear with shackle bolts. Is the fender bashed in? If so I would think it would be pushed pretty far in.
Offline fiddler
« Reply #2 on: April 01, 2013, 11:41:43 pm »
Maybe because this stepside has the 56 inch springs as opposed to the 52 inch springs?  If you have 52 inch springs my guess is the shackle would be placed 4 inches forward from where it is on my 74.  This would allow plenty of clearance.  This one is a Rubik's cube to take apart.  Remove front bolt.  Remove u bolts.  pull spring forward to get clearance on the back for tools.  Then remove spring to shackle bolt.  Now in my case the shackle looks like it's original and was pretty dry.  I decided to replace it as well.  I think they must build the chassis and install the spring bolts before bolting on the box and fenders.  Anyway, pulled the nut off of the shackle through bolt and drove it out enough to get my sawzall on it.  I cut off the head of the shackle through bolt and pulled it out using vice grips.  I ended up using an old long 3/16 bit as a punch to drive one of them out, then had to work the now jammed bit out because it got on the bottom edge of the body and wedged in.  Luckily plenty of bit to work with and pull on.  Got it out without damage to the bit or the truck. Now I am back to stock height.  Thanks for your response.
ricky
Ricky
« Reply #3 on: April 02, 2013, 08:52:58 pm »
     Should have took pics, would have liked to see that.
