Author Topic: Parking brake  (Read 4769 times)
Offline Silverado1979
Parking brake
« on: April 01, 2013, 06:52:44 pm »
I've got a 79 and there is an issue where the parking break lever hangs down far enough to turn on the brake light on the dash and it is really annoying. If I lift it up with my foot it goes away but it eventually falls back down. I was wondering if there was any way to tighten it so it won't sag down. If there is no solution I guess I would have to get a string or something to hold it up? I'm pretty sure this is not a rare problem. Thanks.
Re: Parking brake
« Reply #1 on: April 01, 2013, 07:40:04 pm »
Check for a broken/missing return spring on the pedal assembly.
Offline PromiseKeeper
Re: Parking brake
« Reply #2 on: April 02, 2013, 10:48:28 am »
could be the cables underneath the truck have come loose from one of the tensioners ... you can adjust it from down there too
