Author Topic: Installed new parking brake cables  (Read 4755 times)
Offline pedigo78
  • Big Blue
« on: April 02, 2013, 07:19:56 pm »
So I decided the only way i would get anything done my big blue, was to actually take leave from work. So today I made a junk yard run for a few things i need for my parking brake lines. It was a local junk yard and i was impressed. But on the plus side i got all new lines ran from front to back. just need to get the truck on jack stands and take a look at the brakes and make adjustments.
Sgt Pedigo USMC
Offline velojym
Re: Installed new parking brake cables
« Reply #1 on: April 02, 2013, 08:03:30 pm »
Any major issues to watch out for? This is on my list, too, as the rear part of my brake cables is missing.
« Reply #2 on: April 02, 2013, 08:46:54 pm »
     The pic could be deceiving, but is that cable touching the drive line ?
Offline pedigo78
  • Big Blue
« Reply #3 on: April 02, 2013, 09:49:04 pm »
@velojym, No it was pretty simple. Although i had already ran the rear drum cables so i just need to hook up the rest. If you have a body lift you will lose some length in the cable when you applie the pedal.
@bake74 no it isnt touching there is a good amount of room between the two.
Sgt Pedigo USMC
