Author Topic: radio interfeance  (Read 4974 times)
Offline pedigo78
  • Big Blue
radio interfeance
« on: April 02, 2013, 10:10:54 pm »
So, I when start my i have engine interferance coming out of the radio. I have heard of this before but for the life of me cant remember what i need to be checking. Guess i need to check grounds
« Last Edit: April 02, 2013, 10:14:57 pm by pedigo78 »
Sgt Pedigo USMC
Re: radio interfeance
« Reply #1 on: April 02, 2013, 10:41:57 pm »
To start, make sure the hood is grounded with a strap.  Try using the one dangling off your firewall that you mentioned in a separate thread.  And, check the antenna lead connections to the radio and antenna.  If you have a mast antenna, make sure the base is anchored to a clean ground.
« Last Edit: April 04, 2013, 12:37:25 pm by bd »
« Reply #2 on: April 04, 2013, 12:34:51 pm »
Sargent, is the interference a "whiirrrrrrr" or "zzzZZZZZzz" sound that changes with RPM?  A 'whir' is often associated with alternator operation, while a 'zzz' is generally ignition noise.  Follow this link for useful information: Electrical Noise Prevention.
