Author Topic: Oil Gauge  (Read 8506 times)
Offline pedigo78
  • Big Blue
Oil Gauge
« on: April 03, 2013, 02:58:22 pm »
Found a new 80 psi gauge at the junk yard. Put it in as soon as i got home.
Sgt Pedigo USMC
Re: Oil Gauge
« Reply #1 on: April 03, 2013, 03:16:46 pm »
Looks like it belongs there.  Did you install an 80 PSI sender, too?
Offline pedigo78
  • Big Blue
Re: Oil Gauge
« Reply #2 on: April 03, 2013, 03:26:09 pm »
well i am not sure what psi the sender is actually, how would i be able to tell?
Sgt Pedigo USMC
Re: Oil Gauge
« Reply #3 on: April 03, 2013, 08:11:15 pm »
If the old gauge was 0-60 PSI, you have a 60-PSI sender.  The sender will be stamped "60" on one flat of the 9/16" hex nut adjacent to the threaded end of the sender.  I think the GM part number for the 80-PSI sender with 1/8" male pipe thread is 15591103, but you should verify that.
Offline pedigo78
  • Big Blue
Re: Oil Gauge
« Reply #4 on: April 03, 2013, 09:16:28 pm »
ok thanks ill check it out.
Sgt Pedigo USMC
