Author Topic: circuit card  (Read 4725 times)
Offline pedigo78
  • Big Blue
circuit card
« on: April 06, 2013, 08:40:23 pm »
ok, I have the gauge panel with the big fuel gauge and i want to replace my little clock with a the stock smaller one, and then put the stock tach in place of the big fuel gauge. SO my  question is if i switch the print cards, would it work when i switched the gauges?
Sgt Pedigo USMC
Re: circuit card
« Reply #1 on: April 06, 2013, 09:03:47 pm »
78-80 cluster swap would work for you meaning the circuit would have to come out of those years for the pigtail to plug in. then your power and ground wire along with a lead to the tach on the coil.
Offline pedigo78
  • Big Blue
Re: circuit card
« Reply #2 on: April 06, 2013, 11:48:20 pm »
but not at 85 cluster?
Sgt Pedigo USMC
Re: circuit card
« Reply #3 on: April 08, 2013, 07:04:54 pm »
afaik no. cant say for sure but im pretty sure 81-87 are different then pre 80
Re: circuit card
« Reply #4 on: April 10, 2013, 12:03:04 pm »
It most likely won't work the tach opening is not the same as the fuel  opening also.
Offline pedigo78
  • Big Blue
Re: circuit card
« Reply #5 on: April 10, 2013, 02:18:07 pm »
ok
Sgt Pedigo USMC
