Members Rides
82' C10 2wd shortbox protouring project
Topic: 82' C10 2wd shortbox protouring project (Read 22322 times)
Protouring82C10
welder/fabricator
April 12, 2013, 03:25:50 pm »
I bought this running truck for $1,400. It was basically ready for paint but I didn't want to paint the body with other things looking bad. I decided to do an off frame restoration and throw a bunch of goodies on it while I assemble it back together. It's going to be a great ride when I'm done.
Last Edit: April 12, 2013, 03:40:13 pm by Protouring82C10
Nitrous are for fags, it's called cubic inches...
Protouring82C10
welder/fabricator
Re: 82' C10 2wd shortbox protouring project
April 12, 2013, 03:36:35 pm »
The tear down kept me busy for a few days and i sold $1,305 worth of unwanted parts including the I6 with Saginaw 4 speed. Next thing on the checklist is sandblast the frame and do some modification to it before I get it powdercoated.
Last Edit: April 20, 2013, 06:37:10 pm by Protouring82C10
bake74
April 13, 2013, 05:11:58 pm »
That was a great buy for $1400.00. Looking forward to seeing it finished, keep us updated and keep the pics coming.
74 k10, 77k10 Tom
Protouring82C10
welder/fabricator
April 13, 2013, 05:22:50 pm »
Thanks!
Protouring82C10
welder/fabricator
April 20, 2013, 06:52:04 pm »
Today, I picked up a virgin 454 block and a turbo 400 for a total of $175! Good thing that I bought a cherry picker yesterday. I went to Wally World to find some heavy duty trash bags for my 55 gallon barrel for some rust removal for the block with vinegar. Hopefully in 4 or 5 days that I will find out if its a good candidate for a 496 stroker.
Protouring82C10
welder/fabricator
April 26, 2013, 03:07:52 am »
Finally pulled the block out of the barrel after 5 days soaking in vinegar, did some cleaning and inspected the hi-performance block. The block is pretty much junk in my opinion but I still can use it for mock up.
Protouring82C10
welder/fabricator
April 30, 2013, 12:46:05 pm »
I got bored so I decided to clean up the turbo 400 and painted it.
Protouring82C10
welder/fabricator
April 30, 2013, 07:01:03 pm »
Another thing I did today was removing the front crossmember since I decided that I'm going to use aftermarket crossmember with coilovers, rack and pinion setup.
Protouring82C10
welder/fabricator
May 04, 2013, 05:03:13 pm »
Mock up motor and tranny are both done.
Macj1983
May 04, 2013, 07:42:52 pm »
Looking good man. What was wrong with the block?
And thanks for vinger tip how much did it take
Sent from my Kindle Fire using Tapatalk 2
Protouring82C10
welder/fabricator
May 04, 2013, 08:08:28 pm »
Thanks, the block needs 3 new cylinders and I really don't know what really happened in #7 cylinder with the hole, maybe shattered piston. I coated the block with Gunk degreaser, poured 3 gallons of vinegar, and top it off with water. After 5 days, I pulled it out and went over it with a fine steel wool then hosed it off then sprayed it down with WD-40 specialist.
Protouring82C10
welder/fabricator
May 07, 2013, 06:51:04 pm »
Cutting and punching out the rivets ain't no fun. Next on the checklist is take it in to get it sandblasted, powdercoated, then assemble it with full Porterbuilt suspension.
Protouring82C10
welder/fabricator
May 19, 2013, 11:37:27 am »
The mock up motor is nearly complete and only cost me $315!
Protouring82C10
welder/fabricator
May 19, 2013, 03:41:07 pm »
Removed the windshield and cleaned up the firewall.
4x4orDie
New Users
May 19, 2013, 10:05:08 pm »
Looking good man.
Members Rides
