Author Topic: Emissions system  (Read 3688 times)
Offline Mike1973
Emissions system
« on: April 16, 2013, 07:19:49 am »
1985 1/2 ton 2WD 305 V8  So all the emissions...hoses, vacuum lines, air pump, charcoal canister...all that stuff, what can I eliminate, what can I discard to make the engine compartment cleaner and less cluttered?  After years does this stuff even work anymore?
Re: Emissions system
« Reply #1 on: April 16, 2013, 08:24:17 am »
most states wont let you touch that stuff. inspection is a big deal if you remove it you wont pass if you have to pass it again
Offline Mike1973
« Reply #2 on: April 16, 2013, 09:00:45 am »
I'm in a state where there is no testing what so ever.
Offline gildardo01
« Reply #3 on: April 16, 2013, 09:05:36 am »
same here... in FL there is not testing... is your truck TBI or carburated... i would everything except the fuel/charcoal canister.... i would leave that just to prevent having the smell of fuel vapors on hot days...
Offline Mike1973
« Reply #4 on: April 16, 2013, 09:23:20 am »
I should have included that...It has a carb.
Offline gildardo01
« Reply #5 on: April 16, 2013, 11:26:45 am »
well if its a carb... you can take everything out and just leave the carb... but like i said before i would leave the charcoal canister... what kind of carb do you have... is it a quadrajet? thought about installing an aluminum intake and some headers?
« Reply #6 on: April 16, 2013, 11:50:50 am »
if no testing and its not being used you can remove it. but i just like to warn people that its against federal law to tamper or remove any emission device on a vehicle that is taged for the road. tho more than likely unless you say hey cop look what i did, they wont bother you
Offline Mike1973
« Reply #7 on: April 16, 2013, 01:11:44 pm »
yeah it's a Q-jet.  No headers or aluminum intake for this truck.  The truck is solid, no rust but it looks like crap.  it's just the truck I sometimes use to drive to work, haul dirt, wood or whatever (normally I ride one of my bicycles everywhere).  I keep it in top shape, you could drive it across the country tomorrow without a worry.  The only reason I want to strip the crap from under the hood is to access valve cover gaskets easier and the such as well as just a cleaner engine compartment.
