Author Topic: wiper motor wiring help - previous owner put in a dif one and it doesnt work  (Read 4761 times)
Offline deeg money
I have an 87 c20 and the previous owner hooked up a different wiper motor and cut the original connectors off. I was driving in North Dakota when they quit working. Im looking to see if the wiring is correct or if I can fix it. I have checked the fuse and it is good. Are there any other relays that might cause it to quit working?Thanks guys
um wow. i would check those connections since they aint water prof make sure they are getting power
Compare what you have to the wiring diagrams in the Tech section.
