Changing 4x4 to 2wd
Topic: Changing 4x4 to 2wd (Read 11125 times)
BillB
Changing 4x4 to 2wd
April 19, 2013, 09:49:49 am »
Hey guys, I have a 81 swb 4x4 frame with suspension, the transfer case is thrashed, front diff is shot etc....to make a long story short, I have access to a 2wd 81 3/4 lwb, want to know if the front suspension from the 3/4, 2wd will adapt to the 4x4 frame converting from a 4x4 to 2wd? Thanks in advance, finding out here whether this can be done will sure save time and frustration if it cant be done
pholliday1
1990 V3500 Crew Cab
Re: Changing 4x4 to 2wd
April 19, 2013, 03:00:54 pm »
O....Anything can be done the general school of thought is that is requires a lot of fab work. So if you have those items available then have at it.However its not considered an "easy" project what so ever
BillB
April 19, 2013, 08:01:20 pm »
Thanks for the info, was hoping for a bolt on conversion, maybe time to go back to the thinking board.
Tx_Phil
Changing 4x4 to 2wd
April 19, 2013, 08:40:51 pm »
I'm going to show my ignorance here but could you just pull the gut out of the front diff and drop the drive shaft and run it as a 2wd?
Have you looked into salvage yard parts or pick-part stuff? I'm guessing you could repair the diff and transfer case cheaper than converting to a stock 2wd suspension when you factor in time and frustration and such.
zieg85
April 19, 2013, 09:02:05 pm »
A donor frame, nice sharp air chisel and grade 8 bolts. I can't imagine it would be that hard to do. Very time consuming though. Captkaos has a build thread on here doing that same thing on a Blazer.
April 20, 2013, 07:03:57 am »
most if swapping will swap from a 4x2 to 4x4 not this way around. its been over 10 years since i looked at my 86 4x2 can barely remember anything about it. but if i had to i would do like phil said and gut everything and run her
BillB
April 20, 2013, 09:15:29 am »
What I am trying to do is put together a 81 swb stepside 2wd, I have all I need except the swb frame is 4x4 running gear. I am hoping to remove the front axle, springs, etc and use the front suspension from a donor 81 3/4 lwb 2wd. The 3/4 lwd frame is in another location so I cannot compare the 2 side by side, I am thinking the frames are identical so I will be able to make the switch. I will pick up the 3/4 frame next week so will compare then, was just hoping that this swap had been done before so I would have my ducks in a row before I start. Thanks.
April 20, 2013, 09:55:59 am »
the frames are the same from what i compared 1/2 ton to 3/4 ton. might have to drill holes and so on but i think its all pretty simple. done a 4x2 to 4x4 and it was all pretty much cut and paste
Jason S
April 20, 2013, 11:09:59 am »
Are you going to keep the 8-lug brake/wheel setup, essentially building a 3/4-ton shortbed stepside truck?
April 20, 2013, 12:18:27 pm »
lol the little details; not a with 1/2 ton front he would also have to swap rears or the axle shafts if possible
BillB
April 20, 2013, 04:28:31 pm »
Now to show just how quickly things can change in my square body world, if I were to replace the 4x4 front axel setup, hub to hub do I need to match gear ratios (front to rear)? Sorry to show my ignorance here but As you can see I know very little when it comes to 4x4s. (Just an example of how little I do know) lol.
zieg85
April 20, 2013, 04:35:13 pm »
The gear ratios need to match if you are going to use the 4 wheel drive.
BillB
April 20, 2013, 05:03:52 pm »
Thanks zieg85, now for another show of ignorance,is there identification marks on the axels to show the gear ratio? If so where are they located?
zieg85
April 20, 2013, 05:53:09 pm »
Only sure way to tell is take the diff cover off and look at the ring gear, rotate it around, you will see 2 numbers, for example 40/13 which is a 3.08. If they are original to the truck and you have the sticker on the inside of the glove box door it will tell you or give you a RPO code like a HE3 for example. Report your findings.
http://www.rpocodes.com/GM-RPO-codes/gmrpocodesGthroughM.html
should help you know what you have or originally came in the truck
Last Edit: April 20, 2013, 06:23:20 pm by zieg85
Blazin
Blazin new trails!
April 24, 2013, 12:54:36 am »
If you plan to swap the 4x4 over to a 4x2 you also need to swap the rear spring shackles / hangers as well to 2 wheel drive pieces.
Changing 4x4 to 2wd
