Author Topic: trailering special  (Read 10351 times)
Offline Troy Shy
trailering special
« on: April 24, 2013, 09:18:03 pm »
i'm new to this website. I just got a 1979 blazer trailering special. my blazer has 3/4 ton axles. did that come stock with trailering special?
Offline frotosride
    • WFO CONCEPTS
Re: trailering special
« Reply #1 on: April 24, 2013, 10:13:18 pm »
I'm not an expert on this but I don't think they did. Here is something that may help you out. I have known about it for a while but couldn't remember the websit until someone posted it. Do you still have the little stickers in the glove box? If so then look up the RPO codes and they will tell you exactly what your truck should have been equipped with. But either way looks like a good deal for you!!
http://www.rpocodes.com/GM-RPO-codes/gmrpocodesGthroughM.html
Offline Troy Shy
« Reply #2 on: April 25, 2013, 01:23:26 am »
No I don't have the stickers in the glovebox=[ wish I did.
Offline Jason S
« Reply #3 on: April 25, 2013, 07:53:43 pm »
Welcome to the site and howdy from Oklahoma. Post photos when you get a chance.
Quote
By 3/4 ton axles do you mean 8-lug axles? It should have 6-lug axles from the factory.  Swapping out the 10 or 12-bolt 6-lug rear axle for an 8-lug 14-bolt is not uncommon.  The entire front could be swapped or just the outer 8-lug parts swapped.
« Last Edit: April 25, 2013, 08:14:48 pm by Jason S »
« Reply #4 on: April 26, 2013, 04:32:19 pm »
whats the vin?
