Author Topic: Wiring a sunpro aftermarket tach  (Read 18359 times)
Offline Zeked
« on: April 27, 2013, 10:18:08 pm »
I have a sunpro 1000 tach that I have surgically inserted into the dash panel.
Now I have a cool looking dash with 4 wires dangling down.
White. To lamps
Black to ground
Red to Switched Power
Green ???????????
I have a 87 short step with the 350 and TBI. Bone stock
Should the green go to the distributor, or to the neg coil?
If the dist, where on that muther should it attach?
A six pac for anyone withh pics.........
Zeke
Often Wrong......Never in Doubt!
Offline Shawn0331
    • My Blog
« Reply #1 on: April 27, 2013, 10:21:30 pm »
On my 86, there is a spot on the HEI distributor that is labeled "Tach." Plug the wire into that and you're good to go.
1987 Chevy V10 Silverado SWB 5.7 on 33x12.5's
http://www.shawnseeley.com
Online bd
Re: Wiring a sunpro aftermarket tach
« Reply #2 on: April 27, 2013, 10:31:52 pm »
The green wire connects to the "White" distributor pulse wire off the coil (see image).   ;)
Offline blazing816
« Reply #3 on: April 29, 2013, 08:22:20 am »
X2....that's where I put mine.
Online bd
« Reply #4 on: April 29, 2013, 11:06:35 am »
87 TBI used a divorced coil that bolted to the manifold.  On 86 & prior the coil was married to the cap.
Offline Zeked
« Reply #5 on: April 29, 2013, 08:31:36 pm »
So I use the taped off tach wire, right?   Does anyone know what the connector number is?
Thanks
ZekeD
Online bd
« Reply #6 on: April 29, 2013, 08:52:27 pm »
Thanks
ZekeD
Use the taped off tach wire.  Locate a mating OE-type connector at your local parts house.
