Author Topic: Speedometer recalibration  (Read 5536 times)
Offline FOOSE
« on: May 02, 2013, 11:51:58 pm »
Hello,
I'm wondering if anyone knows if I can get some sort of device to recalibrate my mechanical speedometer, I'm building an '83 Chevrolet Silverado with a 700R4 tranny, for now i'll stick with the factory gauges, but I changed the gears to 4:10 gear ratio, the truck is not drivable yet so I can not test drive it, any info will be much appreciated! :D
Thanks
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Speedometer recalibration
« Reply #1 on: May 03, 2013, 07:28:02 am »
is this 2wd or 4wd?
Offline ehjorten
« Reply #2 on: May 03, 2013, 09:01:17 am »
There are speedo gear-ratio adapters such as the ones found on this site:
http://www.transmissioncenter.net/speedometer_calibration_______va.htm
You can change the driven and drive gears for the speedo or you can sometimes add an adapter.
-Erik-
Offline FOOSE
« Reply #3 on: May 03, 2013, 12:41:04 pm »
Its a 2wd and i'll have 22" wheels in the back and 20" in the front, the tire size in the back will probably be 285/40/22, making the tire about 31" in height.
Thanks ehjorten! that site helped a lot!! :D
Offline Fairlane514
« Reply #4 on: May 03, 2013, 12:41:36 pm »
These are good people do deal with...
http://laspeedometergear.com/
