Author Topic: Vacuum pressure  (Read 2677 times)
Offline 79gmc15
Vacuum pressure
« on: May 05, 2013, 08:37:38 pm »
What kind of pressure should I be expecting from my motor? 1986(?) From a van 305, stock pistons/ heads, comp 268 he cam, sp2p intake, q jet. Idle is set by ear but close to 700 rpm. Timing is set by sound/ping/vacuum gauge. The timing tab and balancer dont match up.
Thanks!
Offline Fairlane514
Re: Vacuum pressure
« Reply #1 on: May 06, 2013, 08:01:32 pm »
Your timing mark is probably at the 12 O'Clock position on the 305.  Stock should be around 17-19 inches of vacuum. I have about 17 on my stock Goodwrench 350. I'm guessing with that cam probably around 15 inches.
