Author Topic: R700 slip joing leak  (Read 6704 times)
Offline 76StepSd
« on: May 06, 2013, 03:52:53 pm »
I was looking at the archived threads and came across this http://73-87.com/7387garage/drivetrain/yokeleak.htm my cup is missing i took the tail shaft off to change that "O" ring and nothing but a shaft and tail shaft housing....i mean....do i have to pull the shaft out or what? Never done this before anyone have any ideas?....i am sure you do...:-)  76 Step side C-10 with a i believe early 80's R700 non electronic. will take some pics in a bit.
Offline 76StepSd
Re: R700 slip joing leak
« Reply #1 on: May 06, 2013, 05:45:03 pm »
here at the pics
Offline Fairlane514
« Reply #2 on: May 08, 2013, 06:03:53 am »
The "cup" just slides over the shaft and then tap it into place on the smooth "band" area just behind the speedo gear. You do not have to remove the shaft.
Offline 76StepSd
« Reply #3 on: May 08, 2013, 06:45:49 am »
Hey thanks for your reply .....well i guess mine is missing. Trying to contact transmission parts places. I tell you they are slow to respond except one place and they carry the O rings i need but not the yoke tube or "output shaft sleeve" as it is called.
Offline Fairlane514
« Reply #4 on: May 08, 2013, 05:29:00 pm »
I had mine off recently to change the speedo gear, so it will be a slight interference fit as you tap it on. Mine was positioned about even with the forward most part of the shaft "flat" or smooth part.
Offline 76StepSd
« Reply #5 on: May 09, 2013, 10:18:46 am »
As of yesterday i have all the replacement O rings on order as well as the yoke tube. The yoke tube seems to be a hard item to get from some places....they will email me if there is a problem getting one. Alot of the other transmission houses wont even call back after leaving them a message. I am like WTH!?......then one guy from a company kept emailing me part numbers ....with no prices mind you and it seems like he sends one part number a day. Customer service at alot of places nowadays suck royally. The bone head could have just called me to make things simple....plus they didnt carry the yoke tube. So i went with Makco Transmission Parts, LLC so hopefully things go well with them.
Offline Fairlane514
« Reply #6 on: May 09, 2013, 12:28:29 pm »
Did you try eBay?  Built Right transmissions has been very helpful to me, ask for Jim.   Make sure its spelled  Built Right.....not Rite
Offline 76StepSd
« Reply #7 on: May 10, 2013, 06:04:12 pm »
Makco Transmissions came through for me...i got my parts today....pretty fast i would say. Will also check out Built Right as you mentioned to see what they are about. Will put Yoke tube on tomorrow....the others i can install now since i have the extension housing off of it.
Offline 76StepSd
« Reply #8 on: May 11, 2013, 11:31:09 am »
i noticed when looking up the part numbers for the yoke tube that there were two different ones the number was the same but one had a "U" in front of the number and the other had a "D" in front of the number....whats the difference? you also said "interference fit" i take it the "O" ring end goes toward the Yoke from the drive shaft and the smaller end of tube goes toward the speedo gear smooth section.....guess it doesnt go any other way...LOL.
Offline Fairlane514
« Reply #9 on: May 11, 2013, 01:21:51 pm »
I dont know about the letter difference.  As far as orientation the smaller end goes towards the speedo gear and the "O" ring end is what the yoke slides into. I just tapped it on gently and made sure it was centered on the shaft.
Offline bd
« Reply #10 on: May 11, 2013, 03:34:28 pm »
It's not a bad idea to use a sparing amount of red Loctite to help ensure the sleeve doesn't migrate on the output shaft.
Offline 76StepSd
« Reply #11 on: May 14, 2013, 06:27:32 pm »
put everything back together yesterday....will test drive tomorrow morning. Correct me if i am wrong but does the 350 transmission have the same yoke tube?
