Author Topic: SM465 Bell house  (Read 6661 times)
Offline csdineley
SM465 Bell house
« on: May 07, 2013, 08:14:12 pm »
Hello
Today My wife and I pulled the engine and trans out of my parts truck. The downside is we broke the slave cylinder ear off the bell house, whoops! So is it possible to have it welded back on? Or should I hit up the junk yards?
1987 V20 Custom Deluxe, Vortec Headed 350, SM465,Np205 14Bff 4.10
Offline gildardo01
Re: SM465 Bell house
« Reply #1 on: May 07, 2013, 09:52:50 pm »
you could weld it or find a used bell housing just depends whats cheaper in your area... either will work.. personally i think a used one might be cheaper and more hassle free....
« Reply #2 on: May 08, 2013, 01:12:40 am »
Cast aluminum doesn't weld very good, and is not very strong if you can get it to weld. I would find a used one.
« Reply #3 on: May 09, 2013, 04:15:47 pm »
Offline csdineley
« Reply #4 on: May 14, 2013, 10:10:53 pm »
Think I've found at least one hydro bell house, maybe two at a local junkyard. Question is what would be the best / easiest way to remove them from the trucks? I don't think I'm supposed to bring any jacks or climb under the vehicles. Any suggestions?
« Reply #5 on: May 16, 2013, 06:58:22 am »
depends on the yard but some will pull it for you or they will at least come over and lift the truck up for you. i had one come over to the truck i wanted the axles from, they lifted they truck and cut them off with torches for nothing extra
Offline csdineley
« Reply #6 on: May 16, 2013, 02:41:33 pm »
Well the guy I spoke with at the yard was wrong neither of the two were Hydro bellhouses.
