Author Topic: 2.76 and 2.73 rear axle ratio  (Read 16581 times)
Offline 79brent
  • Shake and Bake!
« on: May 08, 2013, 05:00:00 pm »
OK so I have a 1979 Chevy shortbed that came factory with a 2.76 ratio(according to the factory paper build sheet and the glove box laminated sheet). Did they change the ratio for the 81-87 or something? I always see people saying 2.73. Just a random question that has me curios.
1979 Chevy C10 Silverado package. 350/350
"Lifes a garden DIG it"
Re: 2.76 and 2.73 rear axle ratio
« Reply #1 on: May 08, 2013, 06:10:26 pm »
I have never seen a "GM" 2.76 ratio, but that is just me.
Offline 79brent
  • Shake and Bake!
« Reply #2 on: May 08, 2013, 07:18:07 pm »
Im 99% sure that's what it says. Ill take a picture of it if it does say that. Always had me wondering.
« Reply #3 on: May 08, 2013, 07:52:16 pm »
Sorry about the mis-information...  I did find a 2.76 in the RPO codes...
Offline 79brent
  • Shake and Bake!
« Reply #4 on: May 09, 2013, 09:09:26 am »
Its all good. Don't know what they would chant to go from 2.76 to 2.73. Probably just changed the numbers. Option HC2 I have pictures but they are to large to upload.  :o
Offline Stewart G Griffin
« Reply #5 on: May 09, 2013, 12:15:16 pm »
Is this 1/2, 3/4 or 1 ton?
Offline 79brent
  • Shake and Bake!
« Reply #6 on: May 09, 2013, 01:53:28 pm »
It is my 1/2 ton, the one in the picture. I'm about to swap out those "dog" gears for a 3.73 limited slip off of a 88 chevy longbed, just gotta move the spring perches in a little bit. I've haven't heard of many people with this axle ratio.
« Reply #7 on: May 09, 2013, 02:02:43 pm »
I think the difference is between the 12 bolt 2.76 and the 10 bolt 2.73 in the 1/2 ton pickups
Offline 79brent
  • Shake and Bake!
« Reply #8 on: May 09, 2013, 02:12:20 pm »
Your probably right Zieg. Is there anything bad about the 10 bolt vs the 12 bolt? The 3.73 I have for it is a 10 bolt. I heard the only real difference is .25" in ring gear size. I plan on getting that swapped in once I get the perches moved and the proper U bolts for it.
« Reply #9 on: May 09, 2013, 02:31:55 pm »
I have heard both the 10 and 12 bolt are comparable in the GM truck rear ends.  I have never had anything powerful to break one as all mine have been pretty much stock slug engines...
Offline 79brent
  • Shake and Bake!
« Reply #10 on: May 09, 2013, 02:46:49 pm »
yeah I got a bone stock motor right now in it. Once im able to save up some money I will build but wont go beyong the breaking point of the axle ever.
